Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
  • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
  • The three cables are coded with black sleeves of different lengths. During reassembly:
  • Connect the long-sleeved cable to the center socket.
  • The short-sleeved cable connects next to the screw.
  • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Insertar traducción aquí
