Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 9
Gently push the edges of the display data cable connector away from its socket on the logic board. It is recommended "walk" the connector out of its socket. Simply push the top and bottom corners of the connector and carefully "walk it out" of its socket. Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
  • Gently push the edges of the display data cable connector away from its socket on the logic board.
  • It is recommended "walk" the connector out of its socket. Simply push the top and bottom corners of the connector and carefully "walk it out" of its socket.
  • Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
Insertar traducción aquí
