Saltar al contenido principal
Inglés
Español
Paso 5
Peel off the clear tape from the speaker connections with tweezers. Use your soldering iron to de-solder the two wires from the speaker. Try to minimise the contact time with your iron on the bard to avoid warping and thermal shocking the board. (I used 390 C ~ 740 F)
Desoldering the speakers
  • Peel off the clear tape from the speaker connections with tweezers.
  • Use your soldering iron to de-solder the two wires from the speaker.
  • Try to minimise the contact time with your iron on the bard to avoid warping and thermal shocking the board. (I used 390 C ~ 740 F)
  • Finally remove the 4 x T5 screws that secure the logic board to the back cover.
Insertar traducción aquí
