Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 8
Here begins the cleaning!  You will need the highest concentration Isopropyl Alcohol (Rubbing Alcohol) you can get.  Don't settle with anything less than 90%.  Why?  Well, if it isn't rubbing alcohol, then its water.  Water is conductive and can hurt your phone.  Rubbing alcohol will remove corrosion and will not hurt your phone.
  • Here begins the cleaning! You will need the highest concentration Isopropyl Alcohol (Rubbing Alcohol) you can get. Don't settle with anything less than 90%. Why? Well, if it isn't rubbing alcohol, then its water. Water is conductive and can hurt your phone. Rubbing alcohol will remove corrosion and will not hurt your phone.
  • Scan the phone for any water or corrosion. We will later use the rubbing alcohol to 1) Displace the water. 2) Remove the corrosion.
Insertar traducción aquí
