Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Insert a spudger into the gap between the midframe and the battery at the bottom left corner of the battery. Use the spudger to pry up the battery until you created a small gap underneath. Try your best not to deform the battery during this procedure. Apply some more adhesive remover into the created gap and let it penetrate the adhesive for several minutes.
  • Insert a spudger into the gap between the midframe and the battery at the bottom left corner of the battery.
  • Use the spudger to pry up the battery until you created a small gap underneath. Try your best not to deform the battery during this procedure.
  • Apply some more adhesive remover into the created gap and let it penetrate the adhesive for several minutes.
Inserta un spudger en el hueco entre el marco medio y la batería en la esquina inferior izquierda de la batería.
Utiliza el spudger para levantar la batería hasta que hayas creado un pequeño hueco debajo. Haz todo lo posible por no deformar la batería durante este procedimiento.
Aplica más removedor de adhesivo en el hueco creado y déjalo penetrar en el adhesivo durante varios minutos.
