Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
The adhesive that holds down the battery in the Huawei Mate 20 is extremely strong. In most cases you'll need a combination of high isopropyl alcohol (>90%) and heat to remove it. Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
Battery
  • The adhesive that holds down the battery in the Huawei Mate 20 is extremely strong. In most cases you'll need a combination of high isopropyl alcohol (>90%) and heat to remove it.
  • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  • Apply adhesive remover or high isopropyl alcohol (>90%) in every corner of the battery and let it penetrate the adhesive beneath the battery for several minutes.
  • At this point you can attempt to continue with the following steps. If you aren't able to pry up the battery apply a heated iOpener to the screen to loosen the adhesive beneath. Apply the iOpener for at least two minutes. You may need to repeat the adhesive remover and heat procedure several times during the removal procedure.
El adhesivo que mantiene la batería en el Huawei Mate 20 es extremadamente fuerte. En la mayoría de los casos se necesita una combinación de alcohol isopropílico alto (>90%) y calor para quitarlo.
Intentq no deformar la batería durante el siguiente proceso de extracción. Las baterías de iones de litio de caparazón blando pueden perder productos químicos peligrosos, incendiarse o incluso explotar si se dañan. No emplees fuerza excesiva ni hagas palanca en la batería con herramientas metálicas.
Aplica removedor de adhesivos o alcohol isopropílico alto (>90%) en cada esquina de la batería y déjelo penetrar en el adhesivo debajo de la batería durante varios minutos.
Ahora puedes intentar continuar con los siguientes pasos. Si no puedes levantar la batería, aplica un iOpener caliente a la pantalla para aflojar el adhesivo que hay debajo. Coloca el iOpener durante al menos dos minutos. Es posible que tengas que repetir el procedimiento de eliminación del adhesivo y del calor varias veces durante el proceso de extracción.
