Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Slide an opening pick under the loudspeaker cover where the main flex cable is located. Slide the opening pick around the right side of the loudspeaker cover and start to pry it up. Avoid damaging the antenna cable during this step. Slide the opening pick around the right side of the loudspeaker cover and start to pry it up. Avoid damaging the antenna cable during this step.
  • Slide an opening pick under the loudspeaker cover where the main flex cable is located.
  • Slide the opening pick around the right side of the loudspeaker cover and start to pry it up. Avoid damaging the antenna cable during this step.
Desliza una púa de apertura bajo la cubierta del altavoz donde se encuentra el cable flexible principal.
Desliza la púa de apertura alrededor del lado derecho de la cubierta del altavoz y empieza a levantarlo. Evita dañar el cable de la antena durante este paso.
