Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 14
Paso 14
Use a spudger to pry up and disconnect the fingerprint flex cable. Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth. During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  • Use a spudger to pry up and disconnect the fingerprint flex cable.
  • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
  • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Usa un spudger para levantar y desconectar el cable flexible de huellas digitales.
Antes de instalar un adhesivo nuevo y volver a montarlo, retira cualquier resto de adhesivo del teléfono y limpia las zonas pegadas con alcohol isopropílico y un paño sin pelusas.
Durante el reensamblado, este es un buen punto para encender el teléfono y probar todas las funciones antes de sellarlo. Asegúrate de volver a encender el teléfono completamente antes de seguir trabajando.
Asegura la nueva tapa posterior con adhesivo precortado o cinta adhesiva de doble cara. Después de instalar el cristal trasero, aplica presión durante varios minutos para ayudar a que el adhesivo forme una buena unión, por ejemplo, colocándolo debajo de una pila de libros pesados.
[* black] Use a spudger to pry up and disconnect the finger printfingerprint flex cable.
[* icon_reminder] Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
[* icon_reminder] During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
[* icon_reminder] Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. [guide|126585|After installing the rear glass|new_window=true], apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
