Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 5
Wedge the flat-end of a metal spudger between the base of the device and  the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
  • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
  • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
  • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
Insertar traducción aquí
