Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone. Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
  • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
  • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
  • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
  • Repeat the procedure for the second strip on the opposite side of the battery.
  • Be careful not to bend the battery. Breaking the battery is dangerous.
  • Remove the battery with your hands.
Insertar traducción aquí
