Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover. The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away. The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
  • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Insertar traducción aquí
