Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Paso 4
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass. If your display is badly cracked, covering it with a layer of clear packing tape may help the suction cup to stick. Alternatively, you can use very sticky tape instead of the suction cup. Or if all else fails, you can superglue the suction cup to the broken screen.
  • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  • If your display is badly cracked, covering it with a layer of clear packing tape may help the suction cup to stick. Alternatively, you can use very sticky tape instead of the suction cup. Or if all else fails, you can superglue the suction cup to the broken screen.
Si estás utilizando una sola ventosa, aplícala al borde inferior del teléfono evitando la porción curva del cristal.
Si tu pantalla está muy agrietada, cúbrela con una capa de cinta adhesiva transparente puede ayudar a que la ventosa se pegue. Alternativamente, puedes usar cinta muy pegajosa en lugar de la ventosa. O si todo lo demás falla, puedes pegar la ventosa a la pantalla rota.s
[* black] If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
[* icon_note] If your display is badly cracked, covering[guide|113372|covering it with a layer of clear packing tapetape|new_window=true] may help the suction cup to stick. Alternatively, you can use very sticky tape [https://d3nevzfk7ii3be.cloudfront.net/igi/NgVMfmOgJwEalMFF.full|instead of the suction cup|new_window=true]. Or if all else fails, you can superglue the suction cup to the broken screen.
