Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side. Rotate the screen 180° and remove the other two screws. You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
  • Rotate the screen 180° and remove the other two screws.
  • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
Insertar traducción aquí
