Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
  • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
  • Remove the metal piece holding in the daughterboard.
  • Disconnect the two cable connectors from the daughterboard.
  • If the cables are stuck, gently wiggle them until they disconnect.
Insertar traducción aquí
