Saltar al contenido principal
Inglés
Español
Paso 2
Remove two PH1 screws Gently pull up on the ribbon retaining tab. Do NOT pull on ribbon. It will slide itself out in final step
Drive PCB
  • Remove two PH1 screws
  • Gently pull up on the ribbon retaining tab. Do NOT pull on ribbon. It will slide itself out in final step
  • Orange/Yellow steps only required if you need to remove the entire PCB
  • Gently pull up on the ribbon retaining tab. Ribbon is attached to underside of PCB via a sticky pad. Gently pull the ribbon away from pad
  • Desolder both points. Red (Left) Black (Right)
  • Gently press up on the PCB where you removed the two PH1 screws and rotate the board upside down
  • If your drive is "dead" this is where I would suggest replacing your electrolytic capacitors. There are 12 on the Thomson drive
Insertar traducción aquí
