Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before you begin, be sure to turn off your laptop and unplug it from the outlet. Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop. Use an opening tool to remove the bottom half of the case from the laptop.
  • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
  • Use an opening tool to remove the bottom half of the case from the laptop.
Insertar traducción aquí
