Saltar al contenido principal
Inglés
Español
Paso 10
Teardown Update: Let's take a closer look at this custom AMD Radeon Pro 580X video card module: When you pull the release latch, it engages two rollers on the opposite side, which simultaneously undock the card and push it away from the mothership motherboard. Unlike the module itself, the silicon inside does not come out with a clever lever! A few sneaky screws are hidden under a giant sticker atop the cooling fins, and then we have to carefully disengage the lever mechanism before we can finally pull out the card.
  • Teardown Update: Let's take a closer look at this custom AMD Radeon Pro 580X video card module:
  • When you pull the release latch, it engages two rollers on the opposite side, which simultaneously undock the card and push it away from the mothership motherboard.
  • Unlike the module itself, the silicon inside does not come out with a clever lever! A few sneaky screws are hidden under a giant sticker atop the cooling fins, and then we have to carefully disengage the lever mechanism before we can finally pull out the card.
  • For our efforts, we are rewarded with the following:
  • The main event! AMD's Radeon Pro 580X, (an iteration of their Pro 500 series for Macs) built on their 14 nm Polaris architecture, featuring 36 compute units.
  • Two rows of Micron GDDR5 VRAM, totaling 8 GB
  • 2x MegaChips MCDP2920, likely something akin to their MCDP2900 DisplayPort 1.4 to HDMI 2.0 converter
  • International Rectifier IR35217 buck controller (similar to the IR35211) and NXP's L6524 I/0 expander
Actualización de Desmontaje: Echamos un vistazo más de cerca a este módulo de tarjeta de video AMD Radeon Pro 580x Personalizado:
Cuando jales del pestillo de liberación, se engancha a dos rodillos en el lado opuesto, lo que al mismo tiempo no cubre la tarjeta y lo empuja lejos de la placa madre base.
A diferencia del módulo en si, el silicio en el interior no sale con una palanca inteligente! Algunos tornillos astutos están ocultos debajo de la pegatina gigante sobre las aleta de enfriamiento, y luego tenemos que desactivar cuidadosamente el mecanismo de la palanca antes de que finalmente podamos sacar la tarjeta.
Para nuestros esfuerzos, somos recompensados con lo siguiente:
¡El evento principal! AMD's Radeon Pro 580xb( una interacción de su cerie Pro 500 para Mac) construida en su alquitectura de 14 nm Polaris, con 36 unidades de cómputo.
Dos filas de Micron GDDR5 VDRAM, totalizando 8 GB.
2x MegaChips CMDP2920, probablemente algo similar a su CMDP2900 DisplayPort 1.4 a HDMI 2.0 convertidor.
Rectificador internacional IR35217 controlador de Buck ( similar al IR35211) y el expansor L6524 I/0 de NXP.
