Saltar al contenido principal
Inglés
Español
Paso 13
What's this? A little baby module! This one's nestled between two groups of DIMM slots and appears to be the speaker. With basically everything else out of the way, we turn our attention to the brains of this whole operation: the CPU, currently trapped beneath its giant heat sink (and some very deeply hidden T15 Torx Plus screws). With no CPU replacement guide to turn to, we call an audible and unscrew the heat sink bracket from the backside of the logic board—releasing both bracket and CPU (Intel Xeon W-3223) from the LGA 3647 socket.
  • What's this? A little baby module! This one's nestled between two groups of DIMM slots and appears to be the speaker.
  • With basically everything else out of the way, we turn our attention to the brains of this whole operation: the CPU, currently trapped beneath its giant heat sink (and some very deeply hidden T15 Torx Plus screws).
  • With no CPU replacement guide to turn to, we call an audible and unscrew the heat sink bracket from the backside of the logic board—releasing both bracket and CPU (Intel Xeon W-3223) from the LGA 3647 socket.
  • We hope Apple is hard at work fleshing out the rest of the service manual for this Pro Mac. (But our hopes aren't too high—we've already started making the instructions they're missing.)
¿Qué es esto? ¡Un pequeño módulo para bebés! Este se encuentra entre dos grupos de ranuras DIMM y parece ser el altavoz.
Con básicamente todo lo demás fuera del camino, dirigimos nuestra atención a los cerebros de toda esta operación: la CPU, actualmente atrapada bajo su gigantesco disipador de calor (y algunos tornillos T15 Torx Plus muy ocultos).
Sin una guía de reemplazo de la CPU a la que acudir, llamamos a un audible y desenroscamos el soporte del disipador de calor de la parte trasera del soporte de liberación de la placa lógica y de la CPU.
Esperamos que Apple esté trabajando duro para desarrollar el resto del manual de servicio de este Mac Pro. (Pero no tenemos mucha esperanza, ya hemos empezado a hacer las instrucciones que les faltan.)
