Saltar al contenido principal
Inglés
Español
Paso 12
The three-fan array comes out in one piece. It's held in place with six screws and connects to the logic board with spring contacts—no fussy cables to deal with! The three tower fans pull cool air through the cheese-grater holes at the front, and push it across the logic board through the various heat sinks. Then the blower fan vacuums up the hot air and spits it out the back. A few interesting things about this arrangement:
  • The three-fan array comes out in one piece. It's held in place with six screws and connects to the logic board with spring contacts—no fussy cables to deal with!
  • The three tower fans pull cool air through the cheese-grater holes at the front, and push it across the logic board through the various heat sinks. Then the blower fan vacuums up the hot air and spits it out the back.
  • A few interesting things about this arrangement:
  • Most tower computers have dedicated fans for the CPU and GPU in addition to fans at the front & rear of the case. The Mac Pro just has front and rear fans, which supposedly provide enough cooling to keep it chill under stress.
  • Another thing most tower computers have: some sort of debris filter to get rid of particles in the air that the cooling fans pull in. Apple's engineers are on record saying they don't need that, but only time will tell how dusty these things get.
La matriz de tres ventiladores sale de una pieza. Se mantiene en su lugar con seis tornillos y se conecta a la placa lógica con contactos de resorte, ¡sin cables molestos!
Los tres ventiladores de la torre aspiran aire frío a través de los orificios del rallador de queso en la parte delantera, y lo empujan a través de la placa lógica a través de los diferentes disipadores de calor. Entonces el ventilador aspira el aire caliente y lo escupe por la parte de atrás.
Algunas cosas interesantes sobre este arreglo:
La mayoría de las computadoras de torre tienen ventiladores dedicados para la CPU y la GPU, además de ventiladores en la parte delantera y trasera de la carcasa. El Mac Pro sólo tiene ventiladores delanteros y traseros, que supuestamente proporcionan suficiente refrigeración para mantenerlo frío bajo presión.
Otra cosa que la mayoría de las computadoras de torre tienen: algún tipo de filtro de desechos para eliminar las partículas en el aire que los ventiladores de enfriamiento jalan hacia adentro. Los ingenieros de Apple dicen que no necesitan eso, pero sólo el tiempo dirá lo polvorientas que se ponen estas cosas.
