Saltar al contenido principal
Inglés
Español
Paso 7
The feet are held in place with just one screw each—although the screws themselves are buried deep in slots in the space frame pillars, making them a bit awkward to access. We make do with a 4 mm hex key and a Mako driver for extra leverage. The screws are held captive inside the frame, so you won't lose those, but we can't say the same for these feet. Better keep an eye on these things so they don't run away. We didn't shell out the $400 for the wheel-y upgrade, so it's nice to know that we don't really need to drag this thing to the Apple store to swap its shoes.
  • The feet are held in place with just one screw each—although the screws themselves are buried deep in slots in the space frame pillars, making them a bit awkward to access. We make do with a 4 mm hex key and a Mako driver for extra leverage.
  • The screws are held captive inside the frame, so you won't lose those, but we can't say the same for these feet. Better keep an eye on these things so they don't run away.
  • We didn't shell out the $400 for the wheel-y upgrade, so it's nice to know that we don't really need to drag this thing to the Apple store to swap its shoes.
  • If you're feeling adventurous and want to attach your own feet or wheels, the screws are M5x0.8. Since we can't remove them, we're unsure of their exact length, but we estimate 15-20 mm. They extend out about 4-4.5 mm from the bottom of the aluminum slab.
Los pies se mantienen en su lugar con un solo tornillo cada uno, aunque los propios tornillos están enterrados en las ranuras de los pilares del bastidor espacial, lo que los hace un poco incómodos para acceder. Nos conformamos con una llave hexagonal de 4 mm y un destornillador Mako para un apalancamiento adicional.
Los tornillos se mantienen cautivos dentro del cuadro, así que no los perderás, pero no podemos decir lo mismo de estos pies. Será mejor que vigiles estas cosas para que no se escapen.
No desembolsamos los 400 dólares para la actualización de la rueda, así que es bueno saber que realmente no necesitamos arrastrar esta cosa a la tienda de Apple para cambiar sus zapatos.
Si te sientes aventurero y capas de ajustar tus propias patas o ruedas, los tornillos son M5x0.8. Cómo no podemos eliminarlos, no estamos seguros de su longitud exacta, pero estimamos 15-20 mm. Se extiende alrededor de 4.4.5 mm desde la parte inferior de la loza de aluminio.
