Saltar al contenido principal
Inglés
Español
Paso 2
From the side, the Mac Pro is about as Apple as they come. Huge, honkin' Apple logo? Check. Cold, hard stainless steel? Check. Precisely milled aluminum slabs? Check. Around back, we spot some ports: a 3.5 mm audio jack, two Thunderbolt/USB-C ports, two USB-As, two HDMIs, two 10 Gb Ethernets, and a run-of-the-mill C14 power plug. Ports are cool, but we're more excited about what's behind all that black plastic: eight PCIe slots, which add up to more upgradability than we've  seen from any Apple product in a long time.
  • From the side, the Mac Pro is about as Apple as they come. Huge, honkin' Apple logo? Check. Cold, hard stainless steel? Check. Precisely milled aluminum slabs? Check.
  • Around back, we spot some ports: a 3.5 mm audio jack, two Thunderbolt/USB-C ports, two USB-As, two HDMIs, two 10 Gb Ethernets, and a run-of-the-mill C14 power plug.
  • Ports are cool, but we're more excited about what's behind all that black plastic: eight PCIe slots, which add up to more upgradability than we've seen from any Apple product in a long time.
  • From above, you can spot two more USB-Cs and what looks like an inconspicuous power LED to the left of the power button.
  • We already got a look at the Mac Pro's two primary handles, but what's this third one up top?
  • Maybe it opens the computer? Nah, it can't be that easy.
Por un lado, la Mac Pro es tan Apple como los demás. ¿Gran logo de Apple? Comprobado. ¿Acero inoxidable duro y frío? Comprobado. ¿Placas de aluminio fresadas con precisión? Comprobado.
En la parte de atrás, vemos algunos puertos: un conector bde audio de 3,5 mm, dos puertos Thunderbolts/USB-C, dos USB-As, dos puertos HDMI, dos puertos Ethernet de 10 Gb y un enchufe de alimentación C14 común y corriente.
Los puertos son geniales, pero estamos más entusiasmados con lo que hay detrás de todo ese plástico negro: ocho ranuras PCIe, que suman más capacidad de actualización que la que hemos visto en cualquier producto de Apple en mucho tiempo.
Desde arriba, puede ver dos USB-Cs más y lo que parece un discreto LED de encendido a la izquierda del botón de encendido.
Ya hemos echado un vistazo a los dos mangos principales del Mac Pro, pero ¿qué es este tercero de arriba?
¿Quizás abre el ordenador? No, no puede ser tan fácil.
