Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 7
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector. Use a spudger or a fingernail to disconnect the digitizer cable connector. If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
Disconnect the front sensors + digitizer
  • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  • Use a spudger or a fingernail to disconnect the digitizer cable connector.
  • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
Usa un spudger o uña para desconectar el conector de cable del ensamblaje del sensor frontal.
Usa un spudger o uña para desconectar el conector del cable del digitalizador.
Si alguna parte de tu pantalla no responde al tacto después de su reparación, desconecta la batería y vuelve a colocar el conector, asegurándote de que encaje completamente en su lugar y de que no haya polvo u otra obstrucción en el zócalo.
