Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 21
Paso 21
Microsoft Surface Pro Repairability Score: 1 out of 10 (10 is easiest to repair) The battery is not soldered to the motherboard, so at least no soldering is required to replace it.
  • Microsoft Surface Pro Repairability Score: 1 out of 10 (10 is easiest to repair)
  • The battery is not soldered to the motherboard, so at least no soldering is required to replace it.
  • The SSD is removable — but you risk killing your tablet by trying to open it.
  • There are over 90 screws inside this device. We're proponents of mechanical fasteners, but this number is a tad crazy.
  • The display assembly (comprising of a fused glass and LCD) is extremely difficult to remove/replace.
  • Tons of adhesive hold everything in place, including the display and battery.
  • Unless you perform the opening procedure 100% correctly, chances are you'll shear one of the four cables surrounding the display perimeter.
Insertar traducción aquí
