Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 10
Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket. Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket. To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
Disconnect the fingerprint sensor
  • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
  • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
  • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
Usa la punta de un spudger para voltear cuidadosamente la barra negra de bloqueo en el zócalo ZIF del sensor de huellas digitales.
Sujeta la lengüeta del cable con tus pinzas y saca suavemente el cable flexible del zócalo.
Para evitar cortocircuitos, evite tocar los contactos metálicos del cable flexible con las pinzas.
[title] Disconnect the fingerprint sensor
[* black] Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
[* black] Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
[* icon_note] To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
