Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 6
Continue heating and slicing the remaining edges of the phone. Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again. Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
Slice through the remaining edges
  • Continue heating and slicing the remaining edges of the phone.
  • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
  • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
Continua calentando y cortando los bordes restantes del teléfono.
Ten cuidado al cortar a lo largo del borde izquierdo del teléfono. Si la púa se siente atascada cerca de la parte superior, es posible que hayas enganchado el sensor de huellas digitales. Retira ligeramente la púa del reborde e inténtalo de nuevo.
Asegúrate de cortar las porciones gruesas de adhesivo cerca de la parte inferior y el borde derecho del teléfono.
