Saltar al contenido principal
Inglés
Español
Paso 5
The battery is secured to the rear case with three pieces of stretch-release adhesive—one near the bottom edge of the battery, one near the top, and one on the right. Each piece of adhesive has one or two black pull-tabs at the end, which are lightly adhered to the side edges of the battery. In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
Locate the adhesive pull-tabs
  • The battery is secured to the rear case with three pieces of stretch-release adhesive—one near the bottom edge of the battery, one near the top, and one on the right.
  • Each piece of adhesive has one or two black pull-tabs at the end, which are lightly adhered to the side edges of the battery.
  • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
  • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
La batería está asegurada a la caja trasera con tres piezas de adhesivo de liberación elástica, una cerca del borde inferior de la batería, otra cerca de la parte superior y otra a la derecha.
Cada pieza de adhesivo tiene una o dos lengüetas negras en el extremo, que están ligeramente adheridas a los bordes laterales de la batería.
En los siguientes pasos, tirarás de cada lengüeta para estirar lentamente el adhesivo debajo de la batería. Estos adhesivos del estilo "command-strip" pierden su pegamento cuando se estiran, así que puedes quitar la batería con facilidad.
Si las tiras se rompen, ¡no te asustes! No siempre funcionan como se pretende. Sigue leyendo para obtener consejos sobre cómo quitar las tiras rotas.
