Saltar al contenido principal
Inglés
Español
Paso 2
Remove the Face ID flex cable bracket. During re-assembly, reinstall the bracket so that it keeps the flex cables separate from the battery. Don't try to slide it between the flex cables and the logic board/camera area.
Remove the bracket
  • Remove the Face ID flex cable bracket.
  • During re-assembly, reinstall the bracket so that it keeps the flex cables separate from the battery. Don't try to slide it between the flex cables and the logic board/camera area.
Remueve el soporte del cable flexible del Face ID.
Durante el re-ensamblaje, vuelve a instalar el soporte que mantiene los cables flexibles de la batería. No intentes deslizarlo entre los cables flexibles entre los cables flexibles y el área de la cámara/placa lógica.
