Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 6
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
  • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
  • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
Si has retirado con éxito todo el sensor de luz ambiental, como se muestra en la primera foto, continúa con el siguiente paso.
Si la tira difusora blanca se desprendió y permanece incrustada en la pantalla, como se muestra en la segunda foto, tendrás que hacer palanca cuidadosamente a lo largo del borde superior con una cuchilla delgada o una herramienta de palanca. Volver a aplicar calor primero puede hacer esta tarea un poco más fácil.
Durante el reensamblaje, instala el difusor en la pantalla primero, asegurándote de que mira en la dirección correcta (el lado que mira hacia adelante se muestra en la primera imagen, y el lado que mira hacia atrás se muestra en la tercera).
Luego, coloca el sensor de luz ambiental en la parte superior del difusor. Tendrás que mantener el sensor en posición mientras instalas los tornillos que aseguran el conjunto auricular/sensor. Una vez que los tornillos estén apretados, el sensor permanecerá en su lugar y funcionará normalmente.
