Saltar al contenido principal
Inglés
Español
Paso 2
Using the Philips #1 Screwdriver, remove the Optical Drive 4.7 mm Philips #1 screw.  Once you remove the screw, locate the metal tab beneath the screw and push it outwards.
  • Using the Philips #1 Screwdriver, remove the Optical Drive 4.7 mm Philips #1 screw. Once you remove the screw, locate the metal tab beneath the screw and push it outwards.
  • It may be useful to use the spudger to push the metal tab, as there is not enough space for your finger or plastic opening tool.
  • Be firm, yet gentle to avoid damaging the electronic connections.
Insertar traducción aquí
