Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 5
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
Lift the display slightly
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Insert an opening pick into the gap.
  • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
Levanta la ventosa con presión firme y constante para crear una pequeña abertura entre el panel frontal y la caja trasera.
Introduce una púa en la pequeña abertura.
El adhesivo impermeable que sujeta la pantalla es muy resistente y podría requerir un gran esfuerzo crear la abertura inicial. Si te resulta difícil crear la abertura, aplica más calor, y mueve suavemente hacia arriba y abajo la pantalla para debilitar el adhesivo hasta que puedas crear una abertura suficiente como para introducir la herramienta.
