Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 4
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass. If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
Si estás utilizando una sola ventosa, aplícala en el borde inferior del teléfono, evitando la porción curvada del cristal.
Si tu pantalla está demasiado rota, puedes cubrirla con una capa de cinta de empacar transparente para permitir que la ventosa se adhiera. Alternativamente, se puede utilizar una cinta muy resistente en vez de una ventosa. Si todo lo demás no funciona, puedes utilizar pegamento instantáneo en la ventosa para pegarla a la pantalla rota.
[* black] If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
-[* icon_note] If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, [https://d3nevzfk7ii3be.cloudfront.net/igi/NgVMfmOgJwEalMFF.full|very strong tape|new_window=true] may be used ''instead of'' the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
+[* icon_note] If your display is badly cracked, [guide|113372|covering it with a layer of clear packing tape|new_window=true] may allow the suction cup to adhere. Alternatively, [https://d3nevzfk7ii3be.cloudfront.net/igi/NgVMfmOgJwEalMFF.full|very strong tape|new_window=true] may be used ''instead of'' the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
