Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the following four connections:
  • Remove the following four connections:
  • Two ribbon cables -- flip up latch and remove horizontally.
  • One wire clamp -- use an opening tool to pry it up vertically.
  • One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
  • The ribbon cable near the wire clamp has a brown tab that should be lifted using an opening tool prior to removal. Be careful to not damage the ribbon or connector.
Insertar traducción aquí
