Traduciendo paso 8
Paso 8
Gently pull the tabs toward the center to release the latches hold the front and back together. These tabs are fragile but release easily. Use caution.
Lean the top forward and lift up to pull the front case from it's bottom latches.
DO NOT TRY TO REMOVE THE FRONT CASE. It is still connected to the back case by several wires and cables.
