Saltar al contenido principal
Inglés
Español
Paso 3
Gently pull the hard drive assembly from the inner drive casing. Using a spudger, gently remove the two adhesive pads holding the paper dust cover in place. If you have a replacement dust cover, you can simply just cut the old cover off. You will need new adhesive pads if you have a new cover or are reusing the old one.
  • Gently pull the hard drive assembly from the inner drive casing.
  • Using a spudger, gently remove the two adhesive pads holding the paper dust cover in place.
  • If you have a replacement dust cover, you can simply just cut the old cover off. You will need new adhesive pads if you have a new cover or are reusing the old one.
Insertar traducción aquí
