Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Turn the laptop to its back side and align it so that the handle is facing away from you. Remove the single 4 mm Phillips #00 screw from the Wi-Fi card/optical drive cover and remove the plastic cover. The Wi-Fi card is located closest to you , below the little strip-sized circuit board.
  • Turn the laptop to its back side and align it so that the handle is facing away from you.
  • Remove the single 4 mm Phillips #00 screw from the Wi-Fi card/optical drive cover and remove the plastic cover.
  • The Wi-Fi card is located closest to you , below the little strip-sized circuit board.
Insertar traducción aquí
