Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 2
Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
  • Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
  • Remove the last 7.5 mm ( 7.2 mm ) Tri-point screw securing the battery to the upper case.
  • Do not remove the label from the battery.
Insertar traducción aquí
