Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Ensure your laptop is fully turned off. Flip it over so the bottom is facing up and the carry handle is facing away from you. Remove the single 4 mm Phillips #00 screw holding the RAM access cover in place. Gently rotate the cover upwards and pull it out. This will reveal the Toughbook’s RAM slots.
  • Ensure your laptop is fully turned off. Flip it over so the bottom is facing up and the carry handle is facing away from you.
  • Remove the single 4 mm Phillips #00 screw holding the RAM access cover in place.
  • Gently rotate the cover upwards and pull it out. This will reveal the Toughbook’s RAM slots.
Insertar traducción aquí
