Saltar al contenido principal
Inglés
Español
Paso 18
Photo 1 and 2, note the tapered edges, these hold the wire clip in place. Reinstallation is simple, just push the on again. This was as far as I was able to go. In my case the part shown on the right in photo 3 was leaking in between the metal and plastic. Sadly it couldn't be disassembled any further. This was as far as I was able to go. In my case the part shown on the right in photo 3 was leaking in between the metal and plastic. Sadly it couldn't be disassembled any further.
  • Photo 1 and 2, note the tapered edges, these hold the wire clip in place. Reinstallation is simple, just push the on again.
  • This was as far as I was able to go. In my case the part shown on the right in photo 3 was leaking in between the metal and plastic. Sadly it couldn't be disassembled any further.
Imagen 1 y 2. Atento a los bordes avellanados, esto mantiene el clip de alambre en su sitio .La reinstalación es simple, solo tienes que juntar y empujar esta parte otra vez en su lugar.
Esto es lo máximo que he podido desmontar. En mi caso, la parte que puedes ver a la izquierda en la tercera imagen, estaba goteando en la unión entre el plástico y el metal. Por desgracia no pude continuar desmontando nada más.
