Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 4
Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off. You may need to use your other hand to safely remove the panel. You can also use a spudger for this step
  • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
  • You may need to use your other hand to safely remove the panel.
  • You can also use a spudger for this step
Insertar traducción aquí
