Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
  • Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
Insertar traducción aquí
