Traduciendo paso 9
Paso 9
Final Thoughts
The 7th-Generation iPad earns a 2 out of 10 on our repairability scale (10 is the easiest to repair):
Non-laminated, separately replaceable cover glass and LCD makes most screen repairs far less expensive.
The LCD is simple to remove once you separate the cover glass/digitizer.
As with all iPads, a solid barrier of very strong adhesive hinders all repairs.
The Lightning port, a common point of failure, is soldered to the logic board.
More adhesive holds nearly everything else in place. Battery and logic board replacements are particularly obnoxious.
