Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Slicing through this much glue isn't our idea of fun... however... we have no followup. Fortunately, much like last time, the glass separates cleanly, leaving the display behind—a surprise to be sure, but a welcome one. That means replacing the iPad 7's cracked glass may be laborious, but at least the materials will still be cheap—you won't have to replace the entire display, like you do on all those other iPad models with LOCA-laminated panels.
  • Slicing through this much glue isn't our idea of fun... however... we have no followup.
  • Fortunately, much like last time, the glass separates cleanly, leaving the display behind—a surprise to be sure, but a welcome one.
  • That means replacing the iPad 7's cracked glass may be laborious, but at least the materials will still be cheap—you won't have to replace the entire display, like you do on all those other iPad models with LOCA-laminated panels.
  • After all that adhesive, we're happy to see the friendly face of a Phillips screw—especially after dealing with all those tiny tri-points last week.
  • This time around, our Battery Blocker only fits into the battery terminal after trimming it down with some scissors, but it's worth the effort to kill the power for a safe LCD extraction.
Cortar esa cantidad de pegamento no es nuestra idea de diversión.... sin embargo.... no hay segunda parte en esta frase.
Afortunadamente, al igual que la última vez, el vidrio se separa limpiamente, dejando atrás la pantalla, una sorpresa, sin duda, pero bienvenida.
Eso significa que reemplazar el vidrio agrietado del iPad 7 puede ser laborioso, pero al menos los materiales seguirán siendo baratos: no tendrás que reemplazar toda la pantalla, como haces en todos esos otros modelos de iPad con paneles laminados LOCA.
Después de todo ese adhesivo, estamos felices de ver la cara amigable de un tornillo Phillips, especialmente después de lidiar con todos esos pequeños tornillos de tres puntos la semana pasada.
Esta vez, nuestro Battery Blocker sólo cabe en el terminal de la batería después de recortarlo con unas tijeras, pero vale la pena el esfuerzo de apagar la energía para una extracción segura de la pantalla LCD.
[* black] Slicing through this much glue isn't our idea of fun... however... there'swe have no second part to this sentencefollowup.
[* black] Fortunately, much like [guide|105416|last time|stepid=198935], the glass separates cleanly, leaving the display behind—a surprise to be sure, but a welcome one.
[* icon_note] That means replacing the iPad 7's cracked glass may be laborious, but at least the materials will still be cheap—you won't have to replace the entire display, like you do on [guide|121759|all] [guide|121589|those|new_window=true] [guide|115457|other] [guide|92534|iPad] [guide|52599|models] with [https://en.wikipedia.org/wiki/Liquid_optically_clear_adhesive|LOCA|new_window=true]-laminated panels.
[* black] After all that adhesive, we're happy to see the friendly face of a Phillips screw—especially after dealing with all those [guide|126223|tiny tri-points|stepid=243651|new_window=true] [guide|126000|last week|new_window=true].
[* black] This time around, our [product|IF145-304-2|Battery Blocker|new_window=true] only fits into the battery terminal after trimming it down with some scissors, but it's worth the effort to kill the power for a safe LCD extraction.
