Saltar al contenido principal
Inglés
Español
Paso 10
Peel the tape up that is covering a small component. Then peel up the remaining component off the enclosure. Not shown: Bend the enclosure apart just enough as to slip the display panel assembly  out of the enclosure. This is scary, and may prove tricky if you are alone. Tip: Call over a buddy and have them hold the two parts of the enclosure apart while you lift the display panel assembly out of the enclosure.
Enclosure removal pt.2
  • Peel the tape up that is covering a small component. Then peel up the remaining component off the enclosure.
  • Not shown: Bend the enclosure apart just enough as to slip the display panel assembly out of the enclosure. This is scary, and may prove tricky if you are alone.
  • Tip: Call over a buddy and have them hold the two parts of the enclosure apart while you lift the display panel assembly out of the enclosure.
Insertar traducción aquí
