Saltar al contenido principal
Inglés
Español
Paso 3
Disconnecting the power requires first extracting the glued-down battery, which we know how to do (although we reserve the right to make a grumpy face as we do it). This year’s energy source is labeled A2181 and provides 1.129 Wh (296 mAh at 3.814 V). That amounts to a very slight 1.44% improvement over last year's 1.113 Wh battery. It's clear that battery improvements didn't drive the switch to the 18-hour always-on display—that technology is being enabled by something else.
  • Disconnecting the power requires first extracting the glued-down battery, which we know how to do (although we reserve the right to make a grumpy face as we do it).
  • This year’s energy source is labeled A2181 and provides 1.129 Wh (296 mAh at 3.814 V).
  • That amounts to a very slight 1.44% improvement over last year's 1.113 Wh battery. It's clear that battery improvements didn't drive the switch to the 18-hour always-on display—that technology is being enabled by something else.
Para desconectar la corriente tenemos que primero extraer la batería pegada. Esto lo sabemos hacer aunque nos reservamos el derecho de poner una cara gruñona mientras lo hacemos.
La fuente de energía de este año se denomina A2181 y proporciona 1.129 Wh (296 mAh a 3.814 V).
Esto presenta una leve mejora del 1.44% respecto a labatería de 1.113 Wh del año pasado. Está claro que las mejoras en la batería no llevaron al cambio a la pantalla de 18 horas siempre activa. Esa tecnología está siendo impulsada por otra cosa.
