Saltar al contenido principal
Inglés
Español
Paso 2
The model number doesn't lie: A2157 tells us it really is a new Apple Watch. Although the usual heat-and-slice action opens up the display, this model was clam-shelled shut a bit tighter than we expected. The Force Touch gasket connector sits in its corner behind the display cables, where it moved with the last iteration.
  • The model number doesn't lie: A2157 tells us it really is a new Apple Watch.
  • Although the usual heat-and-slice action opens up the display, this model was clam-shelled shut a bit tighter than we expected.
  • The Force Touch gasket connector sits in its corner behind the display cables, where it moved with the last iteration.
El número de modelo no miente: A2157 nos dice que este es realmente un Apple Watch nuevo.
Aunque la acción habitual de calentar y cortar abre la pantalla, este modelo está más cerrado de lo que esperábamos.
El conector de junta Force Touch se encuentra en su esquina detrás de los cables de la pantalla. Se movió allí durante la última iteración.
