Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 7
This rectangular battery is held down with a total of six GBs of RAM (Gooey Battery strips), and unfortunately does not share the streamlined removal process that the Pro phones have—to comfortably remove all those adhesive strips, you’re going to have to remove the loudspeaker in addition to the Taptic Engine. That’s not to say that we don’t appreciate the stretch release adhesive—we <3 pull tabs!—but this does complicate the battery replacement process compared to its Pro siblings. This year’s battery measures 40.81 x 96.93 x 3.97 mm, and weighs 44.1 g.
  • This rectangular battery is held down with a total of six GBs of RAM (Gooey Battery strips), and unfortunately does not share the streamlined removal process that the Pro phones have—to comfortably remove all those adhesive strips, you’re going to have to remove the loudspeaker in addition to the Taptic Engine.
  • That’s not to say that we don’t appreciate the stretch release adhesive—we <3 pull tabs!—but this does complicate the battery replacement process compared to its Pro siblings.
  • This year’s battery measures 40.81 x 96.93 x 3.97 mm, and weighs 44.1 g.
  • Compared to the XR’s battery, the 11's is slightly smaller in size, despite the increased capacity. 3110 mAh is the new spec, which is about a 7% increase. That’s not a huge difference, but it probably accounts for some of the supposed extra hour of battery life the iPhone 11 gets .
  • If you prefer your battery stats in Watt-hours—as we generally do—you're looking at a jump from 11.16 Wh to 11.91 Wh.
  • There’s only one connector on this rectangular battery, but it’s still included in Apple’s new-hardware-that-improves-battery-health document. Maybe that means the twin cables in the 11 Pro were for bilateral charging after all, and there’s some other health-boosting hardware difference in the 11 lineup?
Esta batería rectangular está sujeta por un total de 6 tiras adhesivas y desafortunadamente no comparte el ágil proceso de extracción de los modelos Pro: para quitar fácilmente todas estas tiras adhesivas, primero tendrás que quitar el altavoz además del Motor Táptico.
No es que no apreciemos estas tiras adhesivas elásticas - nos encanta tirar de las lengüetas - pero esto complica el procedimiento de reemplazar la batería en comparación con las Pro familiares.
La batería de este año mide 40.81 x 96.93 x 3.97 mm y pesa 44.1 g.
En comparación con la batería XR, la batería 11 es ligeramente más pequeña, aunque tiene más capacidad. Las nuevas especificaciones hablan de 3110 mAh, lo que significa un aumento de alrededor del 7%. No es una gran diferencia, pero probablemente se deba en parte a la hora extra de autonomía acreditada al iPhone 11.
Si prefieres ver los datos de la batería en términos de vatios hora, como hacemos habitualmente, el salto es de 11.16 a 11.91 Wh.
Sólo hay un conector en esta batería rectangular, pero aun sigue incluido en el documento nuevo hardware de Apple que mejora el estado de la batería. ¿Quizás al final los cables dobles del 11 Pro se utilizaron para la carga bilateral? ¿Tal vez haya otras diferencias en el hardware de gestión en el rango de 11?
