Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 7
Locate the plastic clips/tabs that are holding the system board down. There are 2. One by the battery and one by the left-side hinge. Carefully lift upward from the right-side the battery/system board all at the same time.  You will need to lift it up and press in the first tab, and pull it out to the right. Set the system board and battery off to the side.
Remove system board and battery
  • Locate the plastic clips/tabs that are holding the system board down. There are 2. One by the battery and one by the left-side hinge.
  • Carefully lift upward from the right-side the battery/system board all at the same time. You will need to lift it up and press in the first tab, and pull it out to the right.
  • Set the system board and battery off to the side.
Insertar traducción aquí
