Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 6
Remove the 4 screws holding the hinges  to the frame. Be careful that when you loosen them, the screen doesn't fall. Once the screws are removed, carefully close the chromebook until it is only open at around a 20 degree angle, make sure the ribbon will not get caught, and slide the screen off of the Chromebook.
Remove screen
  • Remove the 4 screws holding the hinges to the frame. Be careful that when you loosen them, the screen doesn't fall.
  • Once the screws are removed, carefully close the chromebook until it is only open at around a 20 degree angle, make sure the ribbon will not get caught, and slide the screen off of the Chromebook.
  • Set the screen off to the side.
Insertar traducción aquí
