Saltar al contenido principal
Inglés
Español
Paso 19
We spot what looks like three additional thermal pads lining the back case. However... X-rays reveal that each pad sits atop a clean cut through the steel case lining. The only reason we know of for doing that is RF pass-through. Furthermore, each pad is connected via a flex cable to a complex antenna bus.
  • We spot what looks like three additional thermal pads lining the back case. However...
  • X-rays reveal that each pad sits atop a clean cut through the steel case lining. The only reason we know of for doing that is RF pass-through.
  • Furthermore, each pad is connected via a flex cable to a complex antenna bus.
  • We're not 100% sure what we're looking at, but it seems likely this is our first peek at some ultra wideband antenna hardware.
Vemos lo que parecen ser tres almohadillas térmicas adicionales en la parte trasera de la caja. Sin embargo...
Los rayos X revelan que cada almohadilla se asienta sobre un corte limpio a través del revestimiento de la caja de acero. La única razón que conocemos para hacerlo es la transmisión de RF.
Además, cada almohadilla se conecta mediante un cable flexible a un complicado bus de antena.
No estamos 100% seguros de lo que estamos viendo, pero parece probable que este sea nuestro primer vistazo a algún hardware de antena de banda ultraancha.
