Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 19
Remove the 5 screws using a Philips #2 from the power supply, and lift the power supply straight up and off of the main body. Set it aside. There are 2 power pins connecting the motherboard to the power supply as you remove it. There are 2 power pins connecting the motherboard to the power supply as you remove it.
  • Remove the 5 screws using a Philips #2 from the power supply, and lift the power supply straight up and off of the main body. Set it aside.
  • There are 2 power pins connecting the motherboard to the power supply as you remove it.
Quita los cinco tornillos Phillips #2 de la fuente de alimentación, y saca la fuente de alimentación hacia arriba y fuera del cuerpo cuerpo principal. Coloca todo a un lado.
Mientras quitas la fuente de alimentación, hay 2 pines de conexión que la conectan a la placa base.
